Sponsored by: Real Truck
01' F250 4x4 Problem
Old Apr 17, 2013 | 04:51 PM
mikeallenbrown's Avatar
mikeallenbrown
My truck: 2001 F250 V8 Triton Automatic 4x4
Problem: 4x4 won't engage
Symptoms: No dash lights....nothing happens when I turn the 4x4 switch. When I start the truck I hear what sounds like a motor (transfer case motor maybe?) trying to switch (even though my dash switch is on 2WD)...it trys three times and stops.
What I've done: Checked fuses ...they appear ok to me
I don't have a maintenance manual yet ... hoping someone point me in the right direction. Perhaps there is a thread on here that describes a similar problem?
In the mean time I'll be searching around the forum.
Thank you in advance...
-Mike
EDIT: By the way... the 4x4 used to work up until about 2 weeks ago. Started having a hard time getting it to go into (and out of) 4x4 and then it just stopped all together.
Old Apr 17, 2013 | 05:55 PM
mikeallenbrown
Update: I have power (13v on one of the wires) on the 4x4 switch on the dash. Also, the noise I hear is definitely coming from, what I believe to be, the transfer case motor. It cycles three times after I start the engine. Not sure what that indicates.
Update 2: Relays under the hood appear to be working (They click in sync with the transfer case motor). I swapped them around, same problem & same symptoms.
Sounds like the motor or the gearing/switching mechanism connected to the motor is the problem ... sound about right? ...other threads seem to indicate a "GEM" under the right dash?? ...not sure what a GEM is ...
-Mike
Old Apr 18, 2013 | 09:04 PM
Garybmoe's Avatar
Garybmoe
Sounds familiar
mike, that sounds like identical to the problem I had with my '01 that turned out to be a stripped gear between the shifter motor and the transfer case in the unit you pictured. The light will not come on because it has to shift to trigger the light. I did find a used one that worked, but ultimately put on a new motor and gear reduction unit. Can't remember what it cost--thinking maybe 60 for the used and 100-something for the new. Hope this helps-could be worse news I suppose!
Gary
Old Apr 18, 2013 | 09:24 PM
EXv10's Avatar
EXv10
I don't think you want to know what a Gem module is. It's a very expensive little box that controls the 4WD among other things and you might not even be able to find one. I have heard of people taking them apart and cleaning the contacts in them. I think it is somewhere under the dash on the passenger side.
Seaville
Jan 24, 2017 08:09 AM
Austin J.
1997 - 2003 F150
Sep 11, 2014 05:46 PM
Ron Mantz
Dec 16, 2009 07:42 AM
sprinklerguy
Nov 11, 2006 08:51 PM
SMB
Offroad & 4x4
Jan 8, 2004 02:58 PM
