Sponsored by: Auxito
Yet another 4x4 issue thread...
Old Sep 11, 2014 | 05:33 PM
Austin J.'s Avatar
Austin J.
So, I am having trouble finding a solution to my exact issue. It is a 2000 F-150 4x4 5.4 with dash **** 4x4 switch. When the **** is turned to 4x4 I get an immediate click. Then a second or two later I get a series of clicks for about 5 seconds or so. There is no dash light and the 4x4 is not engaged. It will only do this once . I can turn the **** back of and on and then nothing happens until I restart the vehicle. After restarting it will do the process again.
When the **** is engaged the front drive shaft can be turned by hand so the transfer case is not engaging.
So basically, is it the motor or something controlling the motor that has gone bad?
Old Sep 11, 2014 | 05:43 PM
David7.3's Avatar
David7.3
Could be either or but most likely the motor, there kinda like a window motor and the gear reduction usually go you can unbolt it from the transfer case and have someone operate it, have a pair of pliers with you so you can put a little torque on the motor if you hear that stripping noise you know the motor went.
Old Sep 11, 2014 | 05:46 PM
Austin J.'s Avatar
Austin J.
Alright, I'll give that a try this weekend. If the motor isn't getting power at all what is next in line to check?
mikeallenbrown
Apr 18, 2013 09:24 PM
2000F250guy
Feb 19, 2013 11:26 AM
vinnyhoosier
2004 - 2008 F150
Feb 20, 2008 11:31 AM
