General Automotive Discussion
removing Eclipse radio from E-450 dash
Old Apr 17, 2013 | 12:19 PM
vespaio's Avatar
vespaio
Hi,
I have an RV on a Ford E-450 Super Duty chassis. I would like to remove the radio, but I cannot fully remove the dash--it won't clear the steering wheel. What is the best way to do that, and is it easier to remove the top of the dash rather than the front?
Thanks, Ray
Old Apr 17, 2013 | 11:53 PM
ford2go's Avatar
ford2go
Welcome to FTE
Have no idea, but I'd be surprised if you had to take out the dash. Get a
Chilton's or equivalent for similar trucks of your year. You can probably find something at the library.
Also, you could try asking in one of the sections devoted to your year of truck
On older Fords you just put a couple of metal pins down the sides after removing the trim. Don't know about today's trucks.
Good Luck,
hj
Old Apr 18, 2013 | 07:50 AM
vespaio's Avatar
vespaio
Thanks,
Unfortunately I do. I couldn't find a section devoted to the E-, but did find one devoted to the F-450. Wasn't sure if they were the same section. The pins don't work with this radio. The dash definitely needs to be removed, but I can't get it over the steering column.
vespaio
Metalhead47
Nov 16, 2013 01:44 PM
RDJ184
May 18, 2008 06:53 PM
Gage2502
Aug 11, 2007 09:39 AM
hink10
Sep 21, 2005 03:55 PM
