94 Explorer - CHECK ENGINE LIGHT, Help Please
Old Jun 5, 2003 | 12:15 AM
ElChingon's Avatar
ElChingon
Question 94 Explorer - CHECK ENGINE LIGHT, Help Please
Hello guys, here I am having a problem with my 94 V6 XLT Explorer, you guys have help me B4 and hopefully, you guys can help me now.
Here it goes, This past weekend I had my explorer taken to the shop for a reg. oil change and they also replaced the Air Filter, well after driving for 2 days My Check Engine Light went crazy.
I really dont want to pay tons of money to a dealer so they can check my (EEC) problem. The Check Engine light comes ON after driving for at least 10 to 15 Mins. and stay on for 1 to 2 Mins. and then it turns OFF and after maybe 5 Mins. it comes ON again and so on.
Also another problem I notice, and remember I didn't had any of this problems B4 my oil change, When I press the GAS pedal slowly, I notice that the accelaration stalls (if like is not getting enough gas) but I press the gas pedal on a normal way accelaration its all good.
is this why my check engine comes ON? Im I having a Fuel delivery problem? and is it true that AutoZone check codes for FREE in California
Thank You and hoping for an answer........
Old Jun 5, 2003 | 08:17 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Yes, A/Z will check the codes for free. You really need a code to determine the direction to look. My guess would be an O2 sensor bad, and/or maybe a MAF with dirty wires......
Old Jun 5, 2003 | 10:03 AM
mrshorty's Avatar
mrshorty
On pre-96's, you can also pull the codes yourself with a jumper wire and a voltmeter/test-light. Procedure can be found at www.dalidesign.com under sample pages, among other places on the internet.
Old Jun 5, 2003 | 11:29 PM
Dialtone's Avatar
Dialtone
So all was fine before the grease monkeys fiddled around with things and now the check engine light goes on and off. Start by having codes pulled. My guess you will see something related/pointing to the fuel/air mixture or sensors. Since you mentioned they changed the air filter, start there by checking the air box cover is secure. Now check the wiring harness to the MAF sensor (on the air filter box) where the air duct connects for a loose connector or broken wire. Next, check small hose from the air duct to the oil filler cap to see if it was disloged during filter replacement. Finally, check the air duct from filter box to throttle body connections are tight and duct was not damaged. Sounds like you have an air leak between the MAF and throttle body.
Dialtone
Old Jun 7, 2003 | 12:01 PM
ThePheonixx2's Avatar
ThePheonixx2
i would try cleaning the MAF sensor with a lil carb cleaner...spray it gently and let it completely dry before reinstall.
Old Jun 7, 2003 | 12:46 PM
ElChingon's Avatar
ElChingon
Talking 94 Explorer - CHECK ENGINE LIGHT, Help Please
Hey guys I want to thank everyone, for all your replays, special Thanks to Dialtone & Pheonixx, I did what you guys suggested and guess what, My little probem It's Goneeeee.
once again Thank You.
Tugly
186
Nov 9, 2020 07:47 AM
cjben
Jul 15, 2016 12:33 PM
f350hammer
Jul 22, 2014 10:14 PM
jdbolivar
Escape & Escape Hybrid
Jan 20, 2008 07:43 PM
B287
Bronco II
Mar 12, 2004 11:00 AM
