1985 460 Engine Block Paint Code?
Old Apr 16, 2013 | 05:18 PM
Inside Man's Avatar
Inside Man
Anybody know the paint code for the Gray color on the 460's? I have an 85 F250. How many years did they use this color? Strange to me that it would be a light color such as this, though I suppose you could spot leaks in a quick hurry. I'm assuming that they painted them after the heads and valve covers were together? Thanks guys
Old Apr 16, 2013 | 07:41 PM
Franklin2's Avatar
Franklin2
I don't know the paint code. I just go to the store and buy the "Ford Blue", "Ford Grey", "Pontiac Blue", "Chevy Orange", etc. The vht engine paint is good stuff and sticks pretty well, even if you don't get it clean in some spots. It covers well, no primer needed.
Old Apr 16, 2013 | 07:51 PM
Inside Man's Avatar
Inside Man
As much as I'd like to keep it "Ford Grey", the more I think about it, maybe it would look better if I went with blue, or black. I did my old Camaro small block in black and it looked excellent. I think after the emissions is gone off the block, that "Pale" grey isn't going to look to attractive when you pop the hood and see a bare bones 460 sitting there.
Old Apr 16, 2013 | 08:02 PM
Franklin2's Avatar
Franklin2
Grey is correct, and it probably still has some on there correct? So it's easier to cover if you paint it the same color. And if it flakes off, you won't have blue with grey under it. But you can paint it whatever you like.
Put it all together and then paint it, it helps with minor little oil leaks.
F1 48 Ford
Jan 25, 2009 11:27 PM
RubberDuck
Paint & Bodywork
Dec 5, 2007 01:03 PM
RCMCs 64
Feb 9, 2006 12:46 PM
crawdad
Paint & Bodywork
Jan 26, 2006 07:18 PM
ragmans60
Sep 20, 2003 01:22 PM
