Inner bedside differences
Old Apr 16, 2013 | 04:24 PM
hickory1991's Avatar
hickory1991
I have two 8ft beds that have two different sizes of inner bedside wheel well openings. From the outside everything matches. But inside, the wheel well tub is 10 inches closer to the tailgate. Why did they make these with different openings. Hope I explained it right. The top photo shows bed with around 22-23 inches from back of bed to well opening. Second photo shows about 12-14 inches from back of bed to well opening. I'm curious to why the differences. I thought they were same 73-79.
Old Apr 16, 2013 | 05:00 PM
kevin316's Avatar
kevin316
The one with the opening closer to the rear is from a camper special (I think). It had the axle set back for towing. I'm not sure but I don't think there are many of those left around, might be worth something.
Some one smarter will respond and correct me if I'm wrong.
Old Apr 16, 2013 | 05:06 PM
kevin316's Avatar
kevin316
Here is a pic. Does your have the soare tire door?
WTF. The picture is not working? Never had this problem
Old Apr 16, 2013 | 05:28 PM
grinnergetter's Avatar
grinnergetter
Camper Specials did not have a different wheelbase. Only the Super Camper Special had the rear axle moved back(7" I think)
Only benefit I can think of is having more space for the tire to go when towing.
Old Apr 16, 2013 | 08:33 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
1973 inner wheelhouse is different than 74+
Josh
Old Apr 16, 2013 | 08:58 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The regular long bed (8' bed) had a 133" wheel base. The Super Camper Special had an 8 foot bed also but it had a 140" wheel base.
The SCS also had the spare tire mounted in a special bedside compartment ahead of the right side rear wheel.
Old Apr 16, 2013 | 09:11 PM
Bullitt390's Avatar
Bullitt390
He isn't comparing a SCS and a normal bed. He is comparing a 1973 bed to a 1974+ bed.
The inner wheel well is different on the 1973 versus 74+
Josh
Old Apr 16, 2013 | 09:49 PM
grinnergetter
Thanks Bullitt390...pretty simple reason.
Old Apr 17, 2013 | 05:39 AM
hickory1991
So just the 1973 wheelhousing is different. After 1974 the wheelhousing is shorter? Thanks for the responses.
Old Apr 17, 2013 | 06:45 AM
Bullitt390's Avatar
Bullitt390
73 is a lot like a Bumpside, 74-96 is the same.
Hence why a plastic bedliner fits 74+ and the 73 is excluded.
Josh
SnakeaterZ06
Jul 8, 2019 05:24 PM
SinfulCycles
Jun 17, 2019 01:08 PM
65F1005.8
17
Apr 16, 2014 05:02 PM
blucollar4xford
Jan 28, 2013 04:27 AM
Showpanther
Jul 31, 2006 10:26 PM
