P1780 OBDII code
Old Mar 1, 2005 | 10:05 AM
rangerchief's Avatar
rangerchief
P1780 OBDII code
When I get the code from the computer it's a P1780. I found that the code's description is: P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range, but what does this mean and how do I resolve it. Any and all suggestions/recommendations are welcome. HELP!!!
2001 Ranger 3.0L w/AT
Old Mar 1, 2005 | 02:04 PM
sorensenj's Avatar
sorensenj
Did you get a check engine light or a flashing o/d or something different to indicate you had a problem? I guess what I mean is what prompted you to pull a code? Thanks, hope someone has a answer for you/us!
Old Mar 1, 2005 | 02:21 PM
rangerchief
Yes, the O/D light blinks after driving about 3 miles.
Old Mar 1, 2005 | 08:35 PM
Ken00's Avatar
Ken00
Can you disable the OD by push the TCS?
There are really only three things that can be wrong if you can't, bad wiring, not to likely on a newer truck. A bad TCS, most likely cause. And the last, a bad PCM.
If the TCS works, does the indicator light work?
Wiring and PCM are the possibilities here.
roscozman
Jun 27, 2012 10:53 AM
mhatlen
Mar 14, 2012 09:05 AM
biged52
Aug 4, 2006 02:44 PM
