EFI head question
Old Jun 4, 2003 | 10:37 PM
brucen2son's Avatar
brucen2son
EFI head question
does anyone know if all EFI heads use the same valve size? If not is one year or part # prefered over another? Trying to build torque not max HP.
Old Jun 6, 2003 | 07:13 PM
georgedavila's Avatar
georgedavila
EFI head question
I'm not that familiar with 385 EFI heads, other than knowing there's no aftermarket support, but this'll bring it back to the top where maybe an answer will arrive.
Old Jun 9, 2003 | 10:00 PM
brucen2son's Avatar
brucen2son
EFI head question
i take it no one has any experience with the EFI heads?
Old Jun 10, 2003 | 11:36 PM
daerhldgs2's Avatar
daerhldgs2
EFI head question
all 460 efi heads have same specs and all have a tendency to crack. Ford has introduced a new aluminum head but I think it's for carbs, edelbrock has heads as well.
Old Jun 11, 2003 | 04:35 AM
ludis's Avatar
ludis
EFI head question
There are two different EFI heads: 88-92 and 93-97. I believe the biggest difference is in the ports. Offhand I don't know if the valves are different. This is a question you should ask your machine shop, after all they'll be the ones that will actually do the valve swap.
Hmmm, I think the valves are subtly different. I'm about to change valve stem seals, and the Felpro box says 86 to 92 only. This implies the stem size is different.
abrojal
Sep 17, 2016 11:59 AM
DieseLife
Feb 28, 2015 01:44 PM
Samsn4
Mar 30, 2012 07:47 PM
Onus
Jun 10, 2009 08:33 PM
danlee
Sep 17, 2006 07:16 AM
