Sponsored by: Real Truck
Steering box failed
Old Apr 15, 2013 | 04:31 PM
be250's Avatar
be250
Steering box failed
Hey my 04 f 450 4x4 had the output shaft break off , then i hit tree , anybody seen this? Pitman arm fell off no steering at all
Old Apr 15, 2013 | 04:38 PM
Kdr358's Avatar
Kdr358
Actually, this is about the 4th case of this within a year on FTE. Glad no one got hurt but this is yet another reminder to everyone to check for cracks and new rust forming! How bad is the truck?
Old Apr 15, 2013 | 06:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
So, did the shaft break or the pittman arm fall off?
Old Apr 15, 2013 | 06:33 PM
be250's Avatar
be250
Shaft broke off , then pitman fell with broken part off shaft still tight in it,how would you see this rusting , there is not 1/4" beteewn pitman arm & box? Thanks barry
Old Apr 15, 2013 | 06:36 PM
be250's Avatar
be250
About 3k in damage so not totaled or close ,barry
Old Apr 15, 2013 | 07:48 PM
99f350sd's Avatar
99f350sd
Yes we have heard about it too much lately...I wonder how many nation wide this has happened to. I'm sure all the drivers don't get on the forums.
Dick
Old Apr 15, 2013 | 08:38 PM
clem1226's Avatar
clem1226
second one in the last 30 days I have heard of.
Old Apr 15, 2013 | 10:51 PM
Yahiko's Avatar
Yahiko
Is it time to star doing NDT with the steering box?
NDT (Nondestructive testing) or if you like NDI (Nondestructive inspection)
http://en.wikipedia.org/wiki/Nondestructive_testingThe only problem is you do need to remove the box and the
selector shaft to check it right. I guess you could get away with
only removing the pitman arm and checking the shaft there.
Sean
Old Apr 15, 2013 | 11:12 PM
JWC 3's Avatar
JWC 3
Cardone makes an upgraded box for 05 -10 trucks for this reason . Is there a Problem ???!!
Old Apr 15, 2013 | 11:32 PM
clem1226's Avatar
clem1226
I think I would go with Redhead steering gears for a replacement.
Old Apr 16, 2013 | 06:09 AM
redford's Avatar
redford
I would like to see a picture. The last one I saw that had a broken shaft showed evidence of an old crack that went undetected.
Old Apr 16, 2013 | 02:12 PM
Yahiko's Avatar
Yahiko
The thing is with a crack you can find that with a dye penetrant kit.
You would have to pull the pitman arm and clean the shaft to use the
stuff and it not that expensive of a kit. Clean Spray on and look.
Well this is more to it but not really much. Easy DIY job.
Sean
Old Apr 17, 2013 | 09:04 PM
be250's Avatar
be250
if you think its a easy job you aint done it lately shaft broke off clean ,no rust ,no darkspots the spline was twisted alittle right at the box, the big prob.was with the new box installed the toe in was off like a inch something bent guess sent it on to shop bseg barry
Old Apr 17, 2013 | 09:11 PM
Yahiko's Avatar
Yahiko
The easy part I was referring to was the dye penetrant
part of it. Pulling the pitman is the pits. Joke intended.
Sean
Old Apr 21, 2013 | 06:02 PM
bluef72's Avatar
bluef72
Have all these failures been on 03 and newer trucks?
