power steering leak 97
Old Apr 15, 2013 | 03:41 PM
soonerjeepman's Avatar
soonerjeepman
First, I'm new...
I have a 97 Ford 350E 1 ton van. I have ps fluid leaking out the bottom of the pump where the hard line goes in.
Is this indicative of the pump being bad or maybe a seal on that line?
Had the van with tree wood in it and an empty 18 ft flatbed trailer I was backing up to store.
Thanks for any info.
Old Apr 15, 2013 | 08:22 PM
Talyn's Avatar
Talyn
That fitting is poorly designed.
Figure on going to buy a new PS hose if thats where it's coming out.
The nut fits over a collar on the hard line that eventually wears out and rusts.
If you keep it clean and lubed so it cannot corrode, it will last longer, but that is tough.
You might be able to clean it and get it to re-seat for now.
Old Apr 16, 2013 | 08:17 AM
soonerjeepman
ok, thanks for the info.
better than a new pump!
adamkat22
Nov 18, 2013 07:09 PM
DutchB100
Nov 8, 2011 10:54 AM
fx8racer
1997 - 2003 F150
May 10, 2010 07:53 PM
RTM
Jun 26, 2004 07:54 AM
joezee
Dec 28, 2002 10:20 AM
