Brake lights not working.
Old Apr 15, 2013 | 06:48 AM
OBSessed's Avatar
OBSessed
Hi everyone.
I apologize in advance if this specific problem has been covered before. However, I searched and could only find threads pertaining to the ABS light...anyways, here goes.
My brake lights don't work. Turn signals, tail lights, hazard flashers work, but if I hit the brake, nothing happens. What could possibly be the problem? Could there be a wiring issue?
Thanks in advance for any help, it's greatly appreciated!
Old Apr 15, 2013 | 08:14 AM
JWA's Avatar
JWA
Most likely its just the brake light switch, whether pedal mounted or a pressure activated type, I'm not that familiar with that year and model of brake system though.
Old Apr 15, 2013 | 11:31 AM
Franklin2's Avatar
Franklin2
92 still has it on the pedal arm. If you have the third brake light on this truck, and it does not work either, that also points to the pedal switch, or a blown fuse for this circuit.
Old Apr 15, 2013 | 12:12 PM
OBSessed's Avatar
OBSessed
The truck doesn't have a third brake light. I'll have to swing by the parts store later on and ask them for a switch. Thanks for the help!
Old Apr 15, 2013 | 12:16 PM
OBSessed's Avatar
OBSessed
The truck doesn't have a third brake light. I'll have to swing by the parts store later on and get a new brake switch. Thanks for the help, guys!
Old Apr 16, 2013 | 08:24 AM
JWA's Avatar
JWA
We do what we can!
Let us know if the switch was the fix----probably all it is.
Old Apr 19, 2013 | 09:23 AM
projectSHO89's Avatar
projectSHO89
A 92 was SUPPOSED to have a high-mount stop lamp since it's been a requirement since 84...
In addition to the fuse and the switch, it's not uncommon for the wiring to the switch to fail inside the insulation right at or adjacent to the brake pedal switch.
If the fuse is blown and the truck is equipped with cruise, check for a leaky pressure switch on the master cylinder and if recall 05S28 is still open on the truck.
Old Apr 19, 2013 | 07:07 PM
johnday's Avatar
johnday
Pickups were exempt from that until '94 IIRC. My '91 didn't have it, but my '94 did.
sjjones1
Aug 30, 2009 02:26 AM
michaelbrainardatwor
Aug 7, 2008 08:19 AM
Caplax40
1983 - 2012 Ranger & B-Series
Dec 16, 2007 12:07 PM
dueceman
Aug 23, 2006 02:46 PM
Sstream335858
Aug 2, 2005 07:49 AM
