FICM Voltage
Old Apr 14, 2013 | 05:39 PM
waterboy_fishing's Avatar
waterboy_fishing
FICM Voltage
My 03 has been rough starting and smoking for a few seconds when cold. Switched to synthetic in case I had some stiction going on. Went to check my FICM voltage and had 48 volts w/key on, 14 volts buzz test, 19 volts crank. Obviously bad. My question is am I checking the right screw. Tech folder says right side screw closest to the drivers side fender. Mine was this one. Is this the right screw before I condemn this thing?
Old Apr 14, 2013 | 05:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
That's the correct screw to test.
Defiinately no bueno to see those voltages like that.
Talk to ED about a FICM exchange... FICM Repair.com - Your Source for FICM Repair
Josh
Old Apr 14, 2013 | 07:58 PM
waterboy_fishing
What voltage should I have seen on the bottom right terminal? I measured 11.5 volts.
Old Apr 15, 2013 | 03:51 PM
waterboy_fishing
Took my truck in and checked the batteries. They where a little low. Found the alternator was only putting out about 12.9-13.1 volts. Changed it out. I will recheck the FICM voltage as soon as the truck cools off.
Old Apr 15, 2013 | 06:30 PM
diesel_dan's Avatar
diesel_dan
How old are the batts? A lot of times it goes hand-in-hand to change out batts if you're alternator goes (or is weak) -- starting batts are not meant to be off 100% charge for long...
It is a cascading problem: Batteries go or are not fully charged - FICM starts to fail - injectors live a shorter life...
Old Apr 15, 2013 | 07:23 PM
waterboy_fishing
Batteries tested okay but they are getting older. After getting them charged and a new alternator I rechecked the FICM and I now have 48 volts KO, 35 volts buzz test and 48 volts short crank with no start.
bigred66
Jan 21, 2013 09:51 PM
Locorotc
Oct 11, 2012 07:43 PM
1BigBo
Aug 20, 2011 12:46 AM
Towster
Mar 18, 2011 07:25 AM
mrwrench
Oct 5, 2010 08:48 PM
