"Hercules" has started slamming into gear on that first shift after a stop.
Does'nt do it first thing in the morning when fluid is cold. If I baby the throttle, its barely felt. Not talking a blast-off start here, just normal acceleration when warmed up.
Solenoid sticking?? Is that "cleanable"?
Never exceeded 31K on fluid replacements.
Only got 294K on "Herc's" go box. Nothing lasts any more!!
The OEM regulator valves are anodized aluminum. The coating can wear off, over time, causing sticking within the Accumulator VB bore. TransGo makes steel valves to replace them.
