PLEASE HELP!!!!!
Old Apr 13, 2013 | 11:22 AM
FastTimes10's Avatar
FastTimes10
PLEASE HELP!!!!!
I have a 2003 f250 6.0, i was leaving work the other day and i noticed i lost acceleration and the truck just shut off, i put it in N and tried cranking it and would not stay on, pull into lot tried cranking it and threw whit smoke that smelt like diesel and truck sounded like crap, then i look under the hood n stuff and notice i have oil leaking from back of the turbo....ANY ADVICE
Old Apr 13, 2013 | 11:44 AM
mustang_309's Avatar
mustang_309
Have you checked the oil level? Do you have any gauges that read live data, like scan gauge II or one of the smartphone apps like dashboss for IOS or torque for android? They are absolutely necessary diagnosing these truck's. It could be any number of things, oil from behind the turbo could be a bad ICP sensor.
Old Apr 13, 2013 | 11:56 AM
FastTimes10
oil level is good im fixing to have it scanned this afternoon
Old Apr 13, 2013 | 11:58 AM
FastTimes10
i have a edge revolution programmer, banks cold air intake, egr delete, egr cooler 215k miles
Old Apr 13, 2013 | 12:28 PM
04badford's Avatar
04badford
that sounds turbo related althought ICP and IPR are back there too, I would monitor VGT,ICP,IPR,Boost If you unhook ICP will it start?
Old Apr 13, 2013 | 01:36 PM
FastTimes10
i will check that this afternoon, the mechanic ive been going to says its ganna cost me 1800 for new turbo and labor so im just going to go pick it up thiks afternoon and pull the turbo out myself and see whats going on
Old Apr 13, 2013 | 01:38 PM
FastTimes10
im just hoping my motor is not blown
Old Apr 13, 2013 | 02:43 PM
BLADE35's Avatar
BLADE35
1800.00 for a Turbo Im in wrong bis
There is something else wrong it should Idel with bad turbo
get your gauge before you pull it apart
Old Apr 13, 2013 | 05:18 PM
FastTimes10
It stays on if u keep on pumping the pedal but white smoke still comes out and it keep coughing, checked the down pipe off turbo and it has oil splatter on it
Old Apr 13, 2013 | 05:37 PM
BLADE35's Avatar
BLADE35
Right I Understand that
Are you shure its Oil I would just about bet the Turbo is Fine
HERE IS THE KICKER
Even if the turbo seal Leaked Oil Into the Exhaust it would NOT cause the truck to run Bad
All it would do if the turbo oil seal leaked is smoke from Burning Oil BUT NO Drivability issue like your haveing
Im thinking an Injector is Leaking or Stuck Plunger leaking Fuel into the System its Getting into the Exhaust mixing with the Soot so it looks Like Oil
There is a Slim chance you have Both a bad Turbo seal and Bad Inject leaking Fuel
You need to do a Injector Bubble Test First thing
Old Apr 13, 2013 | 05:42 PM
FastTimes10
According to diognostics all the injectors are fine...... I Dnt know much about this motor all advise helps and I figure the only way ill learn is if I start doing the work myself
Old Apr 13, 2013 | 06:30 PM
BLADE35's Avatar
BLADE35
Bubble test is Easy
COMPRESSION/INJECTOR BUBBLE TEST
DTS Articles - Compression Bubble Test
ARE YOU LOOSING ANY COOLANT?????
Old Apr 13, 2013 | 07:04 PM
FastTimes10
No not that I know of coolant level looks just about right
Old Apr 13, 2013 | 07:23 PM
BLADE35's Avatar
BLADE35
The only way I see a Oil Leak at the turbo causing drivability issues is if it leaks fast enough that it cant control the Veins
the VGT uses the Oil Press to Move turbo Veins
here is a Good starting place to read about the truck
6.0L bibblehttp://api.viglink.com/api/click?for...13658989419494
Old Apr 13, 2013 | 07:27 PM
FastTimes10
The truck turns on as long as u press the gas but it's like it struggling to stay on and just shuts off and it blows white smoke, I just hope my motor isn't blown
