Question about idle adjustment.
Old Apr 12, 2013 | 05:17 PM
RadioControlGuy85's Avatar
RadioControlGuy85
guys my dads dad has a 92 ford f150 with a 302.
the problem is, it has a really high idle. you pretty much can put it in drive and it will idle up and down the road,hell i let it idle from behind the building(its a little bit of a hill and a ditch)where i live,
can anyone tell me where the idle adjustment is on this engine?
or could it be somthing else?"
Old Apr 12, 2013 | 05:30 PM
timbersteel's Avatar
timbersteel
Check for codes. It sounds like vacuum leak, but could be anything. There is a throttle stop screw, but don't tamper with it.
You can pull codes with a paperclip or analog meter for free or a code reader for about $35.
Old Apr 12, 2013 | 05:59 PM
88LX5.0H's Avatar
88LX5.0H
There's a certain procedure on Mustangs to adjust the idle, and I assume it's the same on the F150. You can't just start messing with the little stop screw.
Sounds to me like a vacuum leak.
Old Apr 12, 2013 | 06:07 PM
Conanski's Avatar
Conanski
Idles speed is computer controlled so there are no adjustments just a base throttle plate setting that should not be altered, so if something is out of whack the computer won't control it properly. Possible causes range from a sticking throttle cable to a worn throttlebody, to a gummed up IAC valve or a TPS sensor with a dead spot, or you could have a large vacuum or gasket leak. As suggested pull the codes first, if nothing else that will eliminate a bunch of electronic possibilities and then you can focus on the mechanical issues.
Old Apr 12, 2013 | 06:25 PM
RadioControlGuy85
ok thanks guys,
we do have a code reader so ill see what it pulls.
wilevel2
Jul 7, 2009 04:24 PM
Zero Obliquity
May 15, 2009 04:24 AM
scotchy46088f250
Feb 5, 2009 09:37 AM
MonatheGrona94
Oct 10, 2008 11:13 AM
Robert E.
Jun 5, 2007 11:39 PM
