85 ranger help
Old Apr 14, 2013 | 08:50 AM
BigBlockF350's Avatar
BigBlockF350
Originally Posted by tmcalavy
Don't know where your tank is, but there's a simple gauge test for pre-fuel injection ford trucks. On my 68 and 69 F100's, and on my 69 F250, the gauge was in the cab behind the seat. To test those, you pulled a wire off the sending unit on top of the tank and grounded it...if the gauge needle swept all the way to full, you knew your gauge was good and something was wrong with the float (not floating right) or the sending unit (dirty resistance unit). Both were simple fixes, but don't know if this will work with your 85...it should have a low-pressure, mechanical fuel pump, but the fuel tank could be underneath where it might be hard to get to the sending unit wires.
Yes, this method should work.
The wire from your gauge on the dash to the sending unit in the tanks should be yellow/white.
manram
Dec 24, 2014 10:00 PM
72##ford
Oct 9, 2014 03:31 PM
hinzr
Feb 27, 2014 07:41 PM
Dakota360
Mar 6, 2004 12:52 AM
RedRanger1983
May 3, 2002 09:53 PM
