won't run
Old Oct 8, 2014 | 11:28 PM
72##ford's Avatar
72##ford
won't run
Replaced fuel pump ,fuel filter cap ,and rotor a new coil, plugs and wires , new carb it is spitting fuel out the carb and won't idle also I flushed the tank . The condenser lit up when I probed it with the meter. I am stuck I I hit the zero mark on the balancer and rotor is pointing to #1 I am stuck someone please help.....???
Old Oct 9, 2014 | 12:25 AM
Tedster9's Avatar
Tedster9
New condenser? There's a big batch of defectives out there. Substitute known good if that's the case. They really have to be tested at rated voltage, a multimeter can't do that.
Old Oct 9, 2014 | 12:48 AM
51M1's Avatar
51M1
Do you have spark? You could be 180 degrees out on your distributor. (Try swapping the wires across from each other 2 at a time for all 8 wires) Did you remove the distributor? Do you have 9-12 vdc on the positive side of the coil? Is your firing order correct?
Just a couple of things to check....
Old Oct 9, 2014 | 03:31 PM
JEFFFAFA's Avatar
JEFFFAFA
Since you said new carb is spitting fuel I am assuming you mean out of the bowl vent(s) in to the throat of the carb. This can fuel fowl the plugs. So it won't start. The float pivot or needle and seat are messed up.
But you didn't tell us what happened in the beginning. Let us know from the beginning so we can help diagnose the original problem.
manram
Dec 24, 2014 10:00 PM
gmb8585
Jul 23, 2014 01:23 PM
trouble454
19
Jan 30, 2011 03:09 PM
gearshift101
Nov 23, 2004 01:31 PM
gearshift101
47
Nov 15, 2004 04:28 PM
