A carb is usually just held down by 2 or 4 bolts to the intake manifold. I'd say the hardest part is all the other connections. make sure all the wires, vacuum lines, throttle linkges hookup to the same place on the new one, and make sure nothing gets in the way of the linkages. good luck
