6.0 Running rough - Dashboss data
By the way, the contents of the jar is the diesel out of my water trap.
So, the symptoms were running rough, no power, can't get out of it's own way, and oddly was not throwing any codes (unless this is because my new Dashboss was unable to detect the codes it is throwing). Also, while the fuel filters were dirty, there were no metal shavings or grindings found in the HFCM (as I've seen to be the case on a couple of threads here where the HFCM was going bad, and in which cases they were also running rough, week, and no codes).
At this point my plans are to change the fuel filters (obviously
), do the blue spring mod while I'm crawling around under there anyway, get some stanadyne and dump it both in the tank and in the upper fuel bowl when I put in the new filters, and get the fuel pressure sender for the DASHBOSS. As I said, I will post back here if this does not fix the problem or if anything more is found to be wrong.
Thanks to all who helped!!! I appreciate it. Mike
