clutch problems need some advice
Old Apr 10, 2013 | 09:51 PM
ahamm2009's Avatar
ahamm2009
Hey everyone i have a 2002 mazda b3000 with a 5 speed manual and it recently began becoming very hard to go into gear and clutch pedal is pretty stiff. It almost feels like the clutch is not disengaging all the way. Does anyone or has anyone had this problem before and if so what did u do to fix it.
Thank you for your time
Old Apr 11, 2013 | 12:03 AM
04badford's Avatar
04badford
Ahamm, I would say check your fluid level, does your brakes feel spongey or soft petal,
1. fluid level
2. clutch pressure plate
if pressure plate put new throw out bearing in too .
Old Apr 11, 2013 | 12:05 AM
04badford's Avatar
04badford
try bleeding the brake lines, and keep OEM fluid in the res.
Old Apr 11, 2013 | 08:18 AM
tomw's Avatar
tomw
The brake lines are not connected with the clutch master cylinder & slave. Separate systems. Check the brakes if necessary, but they do not contribute to difficulty in putting the transmission into gear nor hard pedal.
Check the master cylinder reservoir, and look for leaks in the master, lines and slave cylinder. If leaking, be prepared to pull the transmission to replace the slave.
If low on fluid, top off with fresh brake fluid.
tom
hall1991
Aug 23, 2012 11:25 PM
ringokman
Jun 8, 2010 10:14 AM
nikolass
13
Apr 23, 2009 09:03 PM
fordguy300
Oct 22, 2008 07:13 AM
Rich'sToys
Aug 30, 2007 05:59 AM
