ScanguageII
Old Apr 10, 2013 | 08:31 PM
1Fastboy's Avatar
1Fastboy
ScanguageII
Anyone running a scanguageII on their PSD? Pros,cons,ect.....
Old Apr 10, 2013 | 08:51 PM
Evan_P's Avatar
Evan_P
Nobody is because you can't. PSD of this era is not OBD-II, so the gauge doesn't work.
Old Apr 10, 2013 | 08:58 PM
1Fastboy's Avatar
1Fastboy
I was under the impression 1994.5+ power strokes are obdII compliant...
Old Apr 10, 2013 | 09:05 PM
JayFinAZ's Avatar
JayFinAZ
Well, in case you're right, I'll tell you that I have a Scangauge II that I used to run on a GMC Canyon, and now use on a VW Jetta. I like the thing, the mileage calculation is pretty accurate once you've adjusted it over a tank or two. What info you can get out of it depends on what the auto make made available. it comes with programming instructions to read various "non-standard" parameters.
Old Apr 10, 2013 | 09:19 PM
1Fastboy's Avatar
1Fastboy
Thanks for the input. I just read that for trucks over 8500GVRW did not require OBDII Requirments so although they are OBDII the PCM for said trucks lack certain PCM parms that allow various kinds of data output...it's like a OBD1.5...lol
Old Apr 11, 2013 | 06:35 AM
cjben's Avatar
cjben
I know zero about PSD trucks. does your truck have an OBD2 diagnostic port? If so then the scangauge may work,but if not it won't.
TheWhiteBeast
17
Dec 7, 2011 07:59 PM
KC8QVO
Jul 19, 2010 09:23 AM
wycowboy
40
Feb 5, 2009 04:32 PM
megawatt00
40
Apr 3, 2008 09:52 PM
