Sponsored by: Real Truck
4X4 not dissengaging
Old Apr 8, 2013 | 10:35 AM
ticker690's Avatar
ticker690
Hi just joined this forum looking for some suggestions. I have and 05 F350 4X4. I put it into 4 wheel drive high yesterday to make sure every thing was working correctly and it was so I went to 4 wheel low and that worked fine. Problem is it won't come out of 4 wheel low. I didn't try to go back to 2 wheel when I was in 4 high. Any suggestions on what to look for? The truck has the electric switch to engage 4 wheel. Thanks ahead of time for any help.
Old Apr 8, 2013 | 02:25 PM
jroberts257's Avatar
jroberts257
after you turn the switch back to 2wd you need to reverse for 10-15 ft to fully disengage the front end. Try that and see if your problem is solved. If so, then it isn't a problem, just normal
Old Apr 8, 2013 | 03:16 PM
ticker690's Avatar
ticker690
Thanks. I tried that but still stuck in 4 low. I've tried pretty much everything I can think of and what the dealer can think of so I guess it's going to the shop.
Old Apr 8, 2013 | 03:32 PM
szpieleusa's Avatar
szpieleusa
As i remember the right sequnce is that You must engage in 4 high staying, not moving and clutch pressed, when it goes to 4 high only then You can switch it to 2wd, not tried to go from 4 low to 2wd directly and think its wrong
Old Apr 8, 2013 | 04:10 PM
greentree ford's Avatar
greentree ford
Check the low to high relay
Old Apr 8, 2013 | 04:16 PM
WestxSRT10's Avatar
WestxSRT10
Also make sure you are on a flat level surface while switching modes.
Old Apr 8, 2013 | 04:21 PM
Tom's Avatar
Tom
This has nothing to do with it, you can go from 4-low to 2wd directly as long as the conditions are met. The truck has to be going less than 3 MPH in neutral with the brake applied.
Old Apr 9, 2013 | 09:44 AM
ticker690's Avatar
ticker690
Thanks everyone for the suggestions. Ended up being the servo motor down on the transfer case.
Old Apr 27, 2013 | 09:20 PM
hargrett's Avatar
hargrett
This worked for me.
Old Apr 27, 2013 | 09:26 PM
pappy19's Avatar
pappy19
If you read your manual, to put into 4 low you stop, put in neutral, turn the **** to 4 low and put your foot on the brake hard until you hear it engage. To get it out, do the reverse; stop, put in neutral, turn the **** to 4 wheel high, hold foot on brake until dis-engages. Once in 4 wheel high, switch to 2 wheel.
Old Apr 27, 2013 | 09:31 PM
Tom's Avatar
Tom
Nope, that's not right. This is from the 2008 Super Duty owner's guide:
Originally Posted by 2008 Super Duty owner's guide
Shifting from 4x4 LOW to 4x4 HIGH or 2WD
1. Bring the vehicle to a complete stop.
2. Place the gearshift in N (Neutral).
3. Move the 4x4 control to the 4x4
HIGH or 2WD position.
4. Hold the shift conditions until the
4x4 LOW indicator light shuts off.
5. If the 4x4 LOW indicator light
does not shut off within 15
seconds, allow the vehicle to move
at a speed below 5 mph (8 km/h),
then repeat steps 2 through 5 while
the vehicle is rolling before
reporting any shift concerns to your authorized dealer
It says "or", which means you can shift directly from 4-lo to 2WD without any stop in 4-hi. These modules are computer controlled, and they are smarter than you guys are giving them credit for.
Old Apr 27, 2013 | 09:39 PM
pappy19's Avatar
pappy19
Try it with your foot on the brake hard and it shifts immediately, either way, in or out.
Old Apr 28, 2013 | 09:02 AM
ticker690's Avatar
ticker690
It ended up being the servo motor. But thanks for the response.
Krlpj05
2004 - 2008 F150
Jun 15, 2015 08:27 PM
lswinnie
Jan 29, 2015 01:28 AM
RussF350
Apr 9, 2012 11:19 AM
dcsmith
2004 - 2008 F150
Sep 21, 2007 03:01 PM
fordman311
1997 - 2003 F150
Apr 2, 2005 01:48 AM
