Smoking with Tick
Old Apr 9, 2013 | 04:05 PM
  #31
run6.0run's Avatar
run6.0run
I know it makes it tough with the injector prob,, but the tick only happens when it's warm??? There was a quick hint of a chirp at shutdown on the video for me. Unless I'm hearing things. Mine would make about 3 chirps at shutdown. I also ran mine with the chirp for about 50k miles. Was the #8 replacement inj a ford from a dealer? At this point I would go ahead and pull the #8 injector and double check the install. Another idea would be to swap injectors with a different cylinder n see if it follows. I can't remember,, are you getting cont balance codes?? It's $10 for each injector you pull cause the copper washer needs replaced.
Old Apr 9, 2013 | 07:11 PM
  #32
steelhead2's Avatar
steelhead2
The way it cranks it kinda sounds like youve got a valve stuck open. Pull the valve cover off and crank it and watch to make sure the valve train is doing what it should.
Old Apr 9, 2013 | 07:43 PM
  #33
chetspencer's Avatar
chetspencer
Thank you for the follow up. The new injectors are from Accurate Diesel Option 2 (new everything) They seem like a really legit company and I would do business with them again. The injectors did not come in Motorcraft boxes though.
6.0L Powerstroke Injectors
I was getting #8CM counts on my ScangaugeII when things hit the fan. None since I changed the 4 driver side injectors.
Old Apr 9, 2013 | 08:01 PM
  #34
chetspencer
Thanks for the input, I'm very close to making a decision to pull the head. It's that or the engine.
Heres my hypothesis: If I do a compression test AE or real and it fails then I would assume it's a valve. If it passes a compression test it's a lifter.
My logic says smoke is due to unburnt fuel due to low compression.
Last if I pull the head I should be able to do a visual on the related cam lobe maybe even see the lifter, not that I could fix it without pulling the engine of course.
Logical?
Old Apr 9, 2013 | 09:59 PM
  #35
chetspencer
I'm just going to leave this very relevant link here:
6.0 Powerstroke head trends • Speed Talk
Every post in it seems to have some excellent information about our 6.0L heads. Enjoy.
Skinner F350
Jul 6, 2015 07:20 PM
alexmartin33
Aug 9, 2011 02:44 PM
Fordflanigan
May 15, 2009 11:22 AM
1994diesel
Jul 20, 2008 09:00 PM
steve03
Nov 29, 2006 11:44 AM
