85 Bronco 300inline 6. Tranny fluid dipstick. - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
Old 09-25-2017, 05:50 PM
Bearjew253 Bearjew253 is offline
Bearjew253 is starting off with a positive reputation.
Exclamation 85 Bronco 300inline 6. Tranny fluid dipstick.
Where in the he'll is this thing ? Also how much tranny fluid should I put in ?
Old 09-25-2017, 09:40 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
a manual tranny doesnt have a dipstick. you should have a fill hole and a drain hole on the trans. to check fluid level you would open that upper fill plug and you want one finger digit before you make contact with the gear oil. so depending on what manual tranny you have will determine amount of gear oil and type to use.
Old 09-26-2017, 01:01 AM
Thank you for that. Are you well versed with broncos ? Can I pick your brain ? Email me directly if I can. [email protected]
Old 09-26-2017, 11:31 AM
keep your questions here on the forum and you will get all the info you need.
Tranny fluid in solenoid connector? nick2064 1987 - 1996 F150 & Larger F-Series Trucks 2 04-04-2017 01:30 PM
Best 6 speed standard tranny fluid? Cowboy45ft 1999 to 2016 Super Duty 4 02-15-2017 02:11 PM
Transmission problem fgadsden75 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 11-15-2016 07:57 PM
Easiest Way To add Tranny Fluid proudfrog Excursion - King of SUVs 10 05-25-2016 11:20 AM
2001 tranny trouble-weird saltbranch 1999 to 2016 Super Duty 6 03-02-2016 10:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
