Sponsored by: Kumho
Pedal drop when engine is started
Old Apr 4, 2013 | 10:46 PM
jcaw53's Avatar
jcaw53
After installing a tci frame mounted power brake and hyd clutch asy on my 53 f100 project. than bleeding the brake hyd sys and clutch hyd sys I have run into a problem, when the engine is started to supply vacume to the booster. the brake pedal will drop about 3 inchs, with the engine off I have a full pedal of brake press, I have dubble checked the push rod adjustment from the pedal to booster and booster to cyl, and have approx 1/4 inch free play to pedal before hyd press to brakes Has anyone run into this problem, or do i have a bad booster ??
SixtyFour
22
Sep 27, 2017 07:11 PM
jasonmesq
Jan 17, 2016 11:48 PM
78F460
Oct 13, 2007 02:58 PM
Bobs55effie
Mar 5, 2007 10:10 AM
dbrick
Apr 18, 2002 03:58 PM
