Just bought a '64 F100 a month ago. Previous owner installed a power booster, bracket and master cylinder from a '72 F250 2wd.
Right now the brake pedal sits very high compared to the gas and clutch. My guess is that the booster push rod that connects to the pedal is too long. Otherwise the brakes operate very well. Just a high pedal.
Looking under the dash I don't see any way to adjust this pushrod to move the pedal closer to the floor. Then looking on RockAuto I see there's two options for '72 power boosters and one with an adjustable push rod (A-1 CARDONE 5473515) and one without.
Does anyone thing this could be my solve? Also looking at the pic of the booster, does something thread into the opening that would connect to my pedal?
Ok so I did some more digging and I realized the PO did put in the booster I linked above as it does have the threaded input rod. Problem is it the rod is just too long.
Here's some pics...
Really high pedal:
Input rod/brake pedal:
Booster:
So all that figured out I think I might try to go for a booster like this (assuming it can mate up to the booster bracket i have)
It's possible all you actually need is the brake pedal from a 1972 truck. I'm not positive about that but my 65 truck has a 1979 booster and the 79 pedal and it is about where it should be.
This pedal is marked with engineering # D7TA-MA, PWR it is for an auto trans. You will likely need one for a standard trans. I suggest contacting this guy and see if he has what you need Flashback F100's - Home
He has taken a bunch of trucks apart and knows a lot about what fits what.
There are TWENTY TWO different brake pedals, NINETEEN different P/B boosters, SEVENTEEN different master cylinders, SEVEN different clutch pedals, I kid you not!
Whatever booster is used must match the brake pedal.
1968/72 F100/350:
There is ONE brake pedal, ONE clutch pedal, with/without P/B makes no difference.
I gave you the brake pedal info, but did not say a 1968/72 pedal will work on a 1964.
AFAIK, it will not work. 1964's use different master cylinders and related parts than 1965 and later.
You gave me the info that there's an insane number of combos for 73-79 trucks. Not really sure what to do with that at this time.
As far as the '72 pedal in my '64 - as I mentioned I have a master cylinder and master combo from a '72 in my '64. The only stock '64 part left in the brake linkage is the pedal.
Set the pedal where you want it, measure that distance to the inside of the booster contact point to connection on the pedal.
Match the profile on the end of the rod and call it a day.
Just my 2 cents
Aaron
Not sure I'd want to do this - if the booster ever fails I'd have to make another custom booster rod again on the replacement. If I'm going to do something to the input rod I'd just rather install that tuff stuff booster with the adjustable rod.
Either way I'd have to take the current booster off and just replacing it doesn't take a bunch of fab work.
This truck isn't close to being original, as it's a Frankenstein Monster with parts swapped from gawd only knows what.
The only way to verify the year is by the last 6 digits of the VIN
Truck has a 1965 grille, 1965/66 upper grille panel and suspended accelerator pedal.
Suspended accelerator pedal: 1965 F100/250 2WD from serial number 696,001; 1966 F100/250 2WD & 1966 F100 240/300 4WD
The front fender emblem was used on the sides of the hood in 1963/64. Only early 1965's used it as a front fender emblem.
Oh i know it's a frankenstein. It's actually a 2wd converted to 4wd. It's got a Dana 60 front axle out of a '79 Ford, a Chevy 14 bolt out back, a 390 out of a Tbird under the hood, and of course the '72 brake setup. Runs and drives great though
I'll look at the VIN later - but I could have sworn when i looked it up when i bought it it was was '64.
