Sprinter Bench in an E Series
Old Apr 4, 2013 | 08:53 PM
SilverE350's Avatar
SilverE350
Lets see if this works. It did!
I've got an adapter plate bent from 10 gage, which duplicates the factory bolt patern and the Sprinter floor brackets bolt to it. I still have to tweak it a bit so this is just a test fit.
Bench is out of an T1N (?) Sprinter 05 or 06. It's a 3 position. 64" wide. Just as wide as the 4 person. It was so wide I actually had to cut off the arm rest pivots. There is a 54" seat available, but this is what came up on Craigslist.
Old Apr 4, 2013 | 08:59 PM
tabijan's Avatar
tabijan
Looks like the E-series isn't wide enough for a Sprinter 4-seater bench.
And they're not cheap - http://www.ebay.com/itm/281087018109
Sixto
93 E150 Chateau 5.8 185K miles
Old Apr 4, 2013 | 09:06 PM
SilverE350's Avatar
SilverE350
Sixto
I think it might be. On a conversion van the interior may be wider than a factory because there is about 3" (7.6 cm) of space between the metal and plastic. See my edit about seat widths.
Old Apr 4, 2013 | 09:29 PM
SilverE350's Avatar
SilverE350
60 bucks on Craigslist. It just showed up one day. I've seen them for $3-500.
Old Apr 5, 2013 | 09:10 AM
tiopet's Avatar
tiopet
That was a really nice setup.
A good idea looking for integrated seat belts.
Old Apr 5, 2013 | 12:43 PM
nlb7928's Avatar
nlb7928
That is terrific!
When you say you have a bracket bent from 10ga...the piece on the bottom is not plywood? Or is the bracket on the other side of that?
Those Sprinter seats, and the ones in the Nissan vans more so, are pretty neat set-ups. I bet the new Transit will have configurable seating like the Nissan. Also, a power sliding door would be nice. But this is about the seats...and your solution is pretty cool!
Old Apr 6, 2013 | 05:58 AM
JWA's Avatar
JWA
WOW! At that price it'd make a great front porch swing too huh?
Good find and thanks for sharing!
Old Apr 6, 2013 | 09:41 AM
SilverE350's Avatar
SilverE350
Originally Posted by nlb7928
That is terrific!
That rusty piece is 48"x25"x 10gage mild steel. With a 1.25" lip on each 48" length. The Sprinter brackets are the silver things. They are ment to recess into the floor and are 1.25" deep.
I copied the Ford bolt pattern and am able to bolt it down at the 1st and 2nd seat positions or in between them for a kind of "Halfback Van" with room for a table in front of it and lots room for whatever behind it. I plan on making the front seats swivel. The seat is a beast though. Definitely not stow and go. More like heave ho!
Old Apr 6, 2013 | 09:56 AM
SilverE350's Avatar
SilverE350
It all depends on the neighborhood....
motorcarmike
Mar 10, 2016 11:56 AM
Nightstick180
Jul 18, 2013 12:29 PM
kevinheap
Dec 4, 2010 09:54 PM
redtanrt10
Dec 4, 2010 11:54 AM
Turbo_Bimmer
Apr 9, 2008 09:50 AM
