Hot injector
Old Apr 3, 2013 | 09:30 PM
jcar486's Avatar
jcar486
Hot injector
I have one injector getting so hot the fuel is melting the plastic return cap. After 5 min. At idle 7 of the injectors are 55-60 deg. The other one was 125 and climbing.
Does anybody know what causes this.?
Any help would be greatly appreciated
Old Apr 3, 2013 | 09:51 PM
therifleman556's Avatar
therifleman556
Stuck injector letting combustion into it? How many miles are on them?
Old Apr 4, 2013 | 01:49 AM
LSO1123's Avatar
LSO1123
That injector is bad. Replacing them all at one time is preferred but at the very least replace that one.
Old Apr 4, 2013 | 02:31 AM
joshofalltrades's Avatar
joshofalltrades
as they said, that injector is junk. if you're flat broke, buy 2 injectors and a return line kit, and carry the second one you bought as a spare. once one injector goes out, they're all pretty tired, and replacing them all is your best option, but carrying a spare can get you by for a long time if necessary.
Old Apr 4, 2013 | 06:37 PM
jcar486's Avatar
jcar486
Thanks guys, just bought the truck for parts,but runs good enough so my son is going to drive it. Shows 249,000 but I have no idea what if anything previous owner did to maintain. I have a good set of used injectors,should I change them all or just the one?
Old Apr 4, 2013 | 06:51 PM
4x4 ext.'s Avatar
4x4 ext.
Use cation when installing used injectors. They accumulate dust from sitting on the shelf. Did the same thing last year and it ran worse. At the least send them out to get cleaned and pop tested. It's not too much money compare to a towing bill.
Old Apr 4, 2013 | 07:03 PM
Forddiesel17's Avatar
Forddiesel17
At 249000 I would just replace them all especially since you don't know that they have been replaced recently.
Old Apr 4, 2013 | 08:04 PM
therifleman556
And the pump, checkbook permitting...
Old Apr 4, 2013 | 10:44 PM
speedwrench72's Avatar
speedwrench72
Don't trow away the old injectors they can be rebult to better than factory spec's by fellas on this forum...
Old Apr 5, 2013 | 08:28 PM
jcar486's Avatar
jcar486
Sorry,I'm new to diesels,what is pop testing?
Old Apr 6, 2013 | 09:35 AM
84-6.9L's Avatar
84-6.9L
Pop testing is used to check the pressure at which the injector cracks open and atomizes fuel. the injector is hooked to a line and a hand pump is used to build pressure, the tester has a gauge on it so the operator can see at what pressure the injector pops open at, also they can check spray pattern and leakdown.
Old Apr 7, 2013 | 01:14 AM
Dark Horse's Avatar
Dark Horse
Who on here rebuilds these Injectors? I have 12 I would like to get rebuilt if the price was reasonable. Since I have recently bought 8 new ones I would put them up for future use.
Old Apr 7, 2013 | 02:37 AM
BruteFord's Avatar
BruteFord
Rather sure he was referring to RacinNdrummin.
1991 F Super Duty
15
Jun 10, 2013 09:28 PM
ConvertedFord
Sep 18, 2012 09:26 AM
JT250
Sep 11, 2012 01:42 PM
nghtrgr
Dec 15, 2008 09:45 AM
paintslinga2010
Nov 16, 2008 12:08 PM
