injector ?
Old Sep 18, 2012 | 07:38 AM
ConvertedFord's Avatar
ConvertedFord
injector ?
My truck overheated due headgasket failure. he said i may need injectors because they overheat and orings will fail. Is there anyway to test these injectors out of the truck or replace the orings?
Old Sep 18, 2012 | 08:27 AM
npccpartsman's Avatar
npccpartsman
Sorry but you're being "sold" a bill of goods here. If you need injector o-rings you can buy a kit to replace ALL the o-rings (not just the installation rings) from Riff Raff cheap. I replaced headgaskets 5 times on the same set of injectors.
Old Sep 18, 2012 | 08:43 AM
ConvertedFord
how tedious is the process of replacing orings
Old Sep 18, 2012 | 08:44 AM
ConvertedFord
oh i forgot to mention my truck was so hot the oil filter started melting.
Old Sep 18, 2012 | 09:26 AM
npccpartsman
If the oil filter standpipe melted then the oil temps were at least 350*. If the standpipe melted and ran through the motor then the MOTOR is junkyard material. Sounds like you have more problems than just headgaskets to me.
IDI-Charlie
23
Oct 28, 2020 08:14 AM
Roasted7
Sep 27, 2012 11:18 AM
JT250
Sep 11, 2012 01:42 PM
JamesHajek
Oct 19, 2010 12:34 AM
jakemb
May 12, 2006 07:20 AM
