Cruse question
Old Apr 3, 2013 | 12:31 PM
the5schlueters's Avatar
the5schlueters
Cruse question
My cruse works fine but when you press in the clutch it wont disengage. It disengages when you hit the brake or press the off button but when you push the clutch it revs up. the clutch safety works you can't start it without pushing the clutch. What could be the cause of this or where should I start looking?
Old Apr 3, 2013 | 03:04 PM
jas88's Avatar
jas88
I believe the clutch safety switch has 2 plungers, one is for clutch interlock, which is working, and the other one is for CC, and it is bad? You can take the clutch safety switch apart and see if the springs or other innards are bad or not. How long have you had the truck? Normally when the switch goes bad, the CC won't work at all. I am wondering if it went bad, the CC stopped working, and a PO bypassed it?
Old Apr 3, 2013 | 03:06 PM
the5schlueters
Originally Posted by jas88
I believe the clutch safety switch has 2 plungers, perhaps one is for clutch interlock, which is working, and the other one is for CC, and it is bad? You can take the clutch safety switch apart and see if the springs or other innards are bad or not. How long have you had the truck? Normally when the switch goes bad, the CC won't work at all. I am wondering if it went bad, the CC stopped working, and a PO bypassed it?
I will take a look thanks.
Old Apr 3, 2013 | 03:08 PM
jas88's Avatar
jas88
I had a SuperDuty truck like that, the CC did not work and it was the switch that was bad, however, the clutch interlock part worked fine.
Old Apr 3, 2013 | 03:10 PM
blue924.9's Avatar
blue924.9
it could be possible that maybe it got stuck (this is unlikely) but i would take a look at the sensor first and see if its bad or stuck then check the wiring to everything
Old Apr 3, 2013 | 04:30 PM
the5schlueters
Thats a hard switch to get to lol. how do you get it out and check it?
Old Apr 3, 2013 | 04:44 PM
Intimnasc's Avatar
Intimnasc
What he said. And I haven't ever priced one since I am too lazy to drive a stick but if its cheap enough heck just buy one.
Old Apr 3, 2013 | 07:46 PM
the5schlueters
I got the switch off. Both springs are fine and it seems to go back and forth fine. Looks a little oxidized and dirty. I will clean it up and put it back on and see if that works.
t-bird1963
Jan 25, 2006 07:35 AM
scurbiedog
1978 - 1996 Big Bronco
Jun 19, 2005 11:14 AM
chadbuddy34
Mar 23, 2004 03:22 PM
tabakko
Nov 18, 2001 01:20 PM
