Clutch Problems
Old Nov 17, 2001 | 10:30 AM
tabakko's Avatar
tabakko
Clutch Problems
1991 F150 4.9L 5sp manule. When I try to start the truck, I have to push extremely hard on the truck to get the starter to engage. This problem started right after the clutch was changes. Is there some kind of a safety switch or contact that can be disabled?
Old Nov 17, 2001 | 05:36 PM
Saxon's Avatar
Saxon
Clutch Problems
There is a switch located under the dashboard on the clutch linkage where it goes through the firewall. Mine did the same thing after a clutch change and I put a shim/spacer, about 1/8" thick, on the back side of the switch bod. The switch is black and cylindrical shaped and wraps around the clutch linkage in front of the firewall.
Old Nov 18, 2001 | 01:20 PM
Pastmaster's Avatar
Pastmaster
Clutch Problems
