Slip yoke
Old Apr 2, 2013 | 08:07 PM
52-F2's Avatar
52-F2
Slip yoke
Hi Guys,
I have a 52 F2 that had a 4.86 rear gear so I replaced it with a 70 Ford 1/2 ton 9" with 3.50 gears. Now the you joint saddle on the stock rear end stuck out farther then the one on the 9". When I slid the drive shaft back into the saddle it came back about 1 1/2" or so farther. Does anyone know where I can get a slip yoke that is longer then the stock one or maybe someone can tell me how may spline it is and the size do I can try to figure out what I need. I really hate to tear mine apart just to put it back together. I was under the truck today and notice there is a little slop there and would feel better if I could get it back farther on the splines. Anyone have any idea's or a yoke that would work better for me. Thanks so much for your time and help. Dennis
PS can anyone tell me how to get a picture icon on my user name like everyone else has.
Old Apr 2, 2013 | 08:44 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Sounds to me like you need to get a longer drive shaft to correctly solve the problem. You can visit wrecking yards with a tape measure or have a drive shaft shop fab one in the right length and correct rear u-joint size at the rear. The cost would be in the neighborhood of $300, balanced, using your yoke and measurements.
Old Apr 2, 2013 | 08:45 PM
kenjh's Avatar
kenjh
pretty sure you need to get a longer drive shaft ..the yoke's are all nearly the same length..my Icon was a surprise ...someone will help you soon
Old Apr 2, 2013 | 10:15 PM
52-F2's Avatar
52-F2
Thanks for your time and help. I was hoping for a easy fix but I guess we all have a dream. Thanks again and have a great evening. Dennis
Old Apr 2, 2013 | 10:48 PM
kenjh's Avatar
kenjh
not a lot of help ..but ..yah always try the "easy " way first ...then do it right .lol!!
Old Apr 3, 2013 | 02:05 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
They make several different length yokes. Measure yours and check wrecking yards, differential shops or online places like summit racing, currie, strange etc... I am talking about the rearend yoke.
Old Apr 3, 2013 | 02:12 AM
truckeemtnfords
This should maybe fix your issue.
Currie Enterprises Racing Rear End Categories
Old Apr 3, 2013 | 09:19 AM
kenjh's Avatar
kenjh
I thought we were at the other end ...Slip yoke ,,trans end ...sorry if I misunderstood .,,neet catalog !!
Old Apr 3, 2013 | 01:09 PM
52-F2's Avatar
52-F2
Your right, but on this truck it is at the support or carrier bearing. The you joint bolts to the rear end and the other goes to the support bearing. It bolts to the support bearing just like it does at the rear end but the yoke slides on splines (16 spline). The yoke I have is about 6 inches long and I need one that is about 7 to 7 1/2" long. I've be looking but sure what I'm looking for. I just thought the fords of the later 50's or 60s with the long wheel base and used the 9" rear end might have a drive shaft that would work on maybe a longer slip yoke. Thanks again for any help, Dennis
Old Apr 4, 2013 | 11:58 AM
truckeemtnfords
If your diff pinion yoke was longer would it not push your existing carrier yoke back onto the splines further like it needs to be?
Old Apr 4, 2013 | 12:04 PM
52-F2's Avatar
52-F2
Yes, if I could find something to move it forward about 1 1/2 to 1 3/4 it would be great. I just thought the slip yoke would be the best way to go.
MightyThor
Jul 31, 2017 02:06 PM
UP77F250
20
Apr 9, 2013 11:46 AM
52-F2
Jan 19, 2010 02:41 PM
J&JProperty
Apr 22, 2009 06:55 PM
Tom92F150
Dec 17, 2004 07:23 PM
