Sponsored by: Real Truck
Installing rear driveshaft
Old Apr 22, 2009 | 10:57 AM
J&JProperty's Avatar
J&JProperty
Quick question about installing the rear 2 piece driveshafts. 2004 SD250 CC4x4 - the rear shaft thew a weight and has been out of balance since(even after getting re-balanced). Got a complete new 2 piece shaft including carrier. Does the new shaft have any type of alignment to it or can I unbolt the old one and put the new one in? - complete shaft from tanny to rear including carrier.
Old Apr 22, 2009 | 11:07 AM
12ozd's Avatar
12ozd
The driveshaft must be "phased"
The yoke must be connected to the slip shaft so the "ears" line up w/ the other end.
One shaft will have two ears parallel,the second shaft will be 90* off.
( pretend the yoke is attached permanently to the slip shaft)
(easier to do than me explain)
Take a good look at the old one , maybe that will help my explanation.
Old Apr 22, 2009 | 11:19 AM
J&JProperty
I think I understand what you are saying. The drive shaft is already together with the slip yoke and carrier(thank you Ford). I'll look at how the one is set up now.
Old Apr 22, 2009 | 11:43 AM
JockD's Avatar
JockD
If the old driveshaft is not properly timed, try putting it in time before replacing it with the new unit. An out-of-time driveline can cause a vibration like you report.
Old Apr 22, 2009 | 05:17 PM
aldridgec's Avatar
aldridgec
The splines in the center of the driveshaft have a pin that allow it to only be installed in one direction. Otherwise, it should be a simple install.
Old Apr 22, 2009 | 06:55 PM
samurai's Avatar
samurai
Not to hijack this thread, but aloong the same lines...
When I orignally got my 6" lift on my truck a couple months ago, the ******** forgot to put a carrier drop bracket on my driveshaft and it was clunking around pretty good for a few days befoore they realized it and called me to fix it.
Ever since then I feel like I did damage to either my driveshaft or transmission because when there is either a heavy load in the bed or I am pulling a trailer a lot of time it will clunk and stutter and actually just die.
Any thoughts if I did damage to the driveshaft originally for those couple of days without a carrier drop bracket or what could cause this? Need to tow my heavy trailer in a couple weeks and I want to resolve this.
THANKS and SORRY for hijacking!
