injector pump shot?
Old Apr 2, 2013 | 06:55 PM
Nick bass's Avatar
Nick bass
injector pump shot?
can anyone out there tell me the symptoms or signs that you ip is crappin out? i recently started leakin fuel like crazy and idling like crap and after hours of investigating i can see that fuel is running from the pump down the valley pan and down the block? doesnt look like its a any of the steel lines that bolt up to it tho. thanks for the help
Old Apr 2, 2013 | 07:38 PM
mudguts's Avatar
mudguts
It sure sounds like the IP How many Miles are on it?
Old Apr 2, 2013 | 07:41 PM
Nick bass's Avatar
Nick bass
not real sure theirs lil over 200k on truck and i know its has a reman pump on it.
Old Apr 2, 2013 | 07:59 PM
mudguts's Avatar
mudguts
From what I have read in here 100,000 seems to be about how long these pumps are good for, If that is the case then I would do injectors at the same time.
Old Apr 2, 2013 | 08:40 PM
Nick bass's Avatar
Nick bass
when replacing the pump i know you need to make timing marks in the gear cover but is their a special mark the pump has to line up with? or is it as long as the timing gear hasnt moved your fine?
Old Apr 2, 2013 | 08:55 PM
ihateminimumwage's Avatar
ihateminimumwage
As long as you just undo the three 12pt bolts holding the pump to the gear, and the three nuts that hold the pump to the housing (DO NOT PULL THE HOUSING/COVER!), it will slide right out and the new one will 'key' right in place because of a dowel pin on the pump. No worries of being 180 degrees out like a gasser distributor, haha.
Old Apr 2, 2013 | 10:12 PM
Nick bass's Avatar
Nick bass
perfect! thats exactly what i was wondering. thank you guys
Old Apr 2, 2013 | 10:24 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Sounds like a seal failed internally if it's leaking like that.
And X2, not hard at all to do an IP on these.
Remove that little round cover on the gear cover just under the oil fill, and you'll see 3 little bolts, take those out, and inbetween the pump body, and gear cover, theres 3 nuts you'll also need to undo to get the pump off.
Old Apr 2, 2013 | 11:18 PM
mudguts's Avatar
mudguts
There is also a mark on the top of the pump housing and the pump has a mark on the top of it when these are lined up you are real close to being in time I think that if you rotate the pump to the passenger side it will retard the timing and towards the driver's side is advance, but I'm not 100% it may be reverse of what I just said But some one on here will know.
Old Apr 4, 2013 | 04:56 PM
Nick bass's Avatar
Nick bass
False alarm guys it ended up being the #2 injector line being cracked. it being in the bottom side of the injector pump of course! does anyone know where i can get that line cheap? as in cheaper than fords $100 price tag.
Old Apr 4, 2013 | 05:38 PM
Dieselexic's Avatar
Dieselexic
salvage yard if you're lucky make sure engine size is the same.
Old Apr 4, 2013 | 07:02 PM
4x4 ext.'s Avatar
4x4 ext.
I've got some pumps laying around. If you can't find one PM me and I'll ship you the line. Don't know what shipping will cost from WA but its an option. The parts store can build you a line as well. The just need the end fittings.
Old Apr 4, 2013 | 09:59 PM
Nick bass's Avatar
Nick bass
yea tried salvage yards. anybody who gets their hand on an idi around here keeps em.
Old Apr 4, 2013 | 10:36 PM
speedwrench72's Avatar
speedwrench72
yeah makes a guy want to start colecting them for parts,, don't ever throw away any injectors..all are rebuildable....
Old Apr 8, 2013 | 09:50 AM
Nick bass's Avatar
Nick bass
while searching for injector lines for my truck (which btw cost way more than i expected) i ran across this line from http://www.ebay.com/itm/Emergency-Diesel-Fuel-Injection-Injector-Line-/271160173036?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2267e1ec&vxp=mtr. great idea i thought for these older truck because they do break at the worst times.
but this got me thinking, why hasn't anyone came out with a set of flex injector lines? they have working pressure of 8350PSI and a burst pressure point of almost 21000PSI which i would think is alot more than the idi can crank out.
doorstop
Oct 25, 2010 11:16 AM
riverrat41
Jan 25, 2009 10:00 AM
jwolfe60
Sep 6, 2007 01:14 PM
DieselMan04
Aug 1, 2003 07:21 PM
puman350
Apr 21, 2002 07:33 AM
