Sponsored by: Auxito
Turn key --- Nothing
Old Apr 2, 2013 | 05:02 PM
SteevenH's Avatar
SteevenH
Went to start my 99 f250LD 4x4 with 5.4 today and nothing happened. I thought it might be the safety switch so I moved the shifter around a little and still nothing. When I turned the ignition switch off there was a ticking sound coming from the inside fuse panel . It clicked about ten times and stopped. It repeated the exact pattern 3 times. I checked the battery cables, I know the battery is good, cables were tight. I said what the hay and tried it again and it started right up. It started again later when I checked. Any Ideas?
Old Apr 2, 2013 | 05:25 PM
steve(ill)'s Avatar
steve(ill)
next time it does it, see if the "theft" light in the top center of the instrument panels stays lit while you crank. I have had two aftermarket keys "fail" in the last week. They were programmed and now do not start, only crank. Originals are still good...Try another key ?
Old Apr 2, 2013 | 05:57 PM
SteevenH's Avatar
SteevenH
I used the original key. No lights came on @ all. Clicking in fuse panel was after key was removed.
Old Apr 3, 2013 | 07:14 AM
Spotty's Avatar
Spotty
Are you sure it was the fuse panel and not the GEM behind it?
Old Apr 3, 2013 | 09:28 AM
SteevenH's Avatar
SteevenH
It could have been. One other thing I left out. The ticking in the panel changed in volume too less loud after I pushed in on the fuse panel.
Sean11
2004 - 2008 F150
13
May 7, 2019 12:27 PM
hobbyman
1983 - 2012 Ranger & B-Series
Aug 4, 2015 03:39 PM
nonickname13
Modular V8 (4.6L, 5.4L)
Nov 24, 2013 08:36 PM
da1gamer
Dec 25, 2004 09:01 AM
