Driving to work today, I noticed a vibration that has progressively gotten worse. I've narrowed it down to the u-joints but if anyone could please give me advice on how to do it or pointers while doing it. I'm not a beginner but I'm not a mechanic by trade either.
If you doing the front I think your also going to need that front seal replacer
and a set of seals. I hear that they get trashed when you pull the axels.
There is a good how to in one of the tech folders.
Not front u-joints if it vibrates. Front u-joint (singular).
Why is the front spinning? Single ujoint on the driveshaft will cause vibration if bad but only in 4wd..
