spark plugs wire pattern?
Old Jun 3, 2003 | 10:19 PM
crazy4Fords's Avatar
crazy4Fords
i need a pictured help with spark plugs wire where it goes and on cap n wires.... my book s don't tell muhc so i m a buit lost now i have the firing pattern but i dont know where to have it on the cap or whichones goes where ... help me!! forgot to tell it s a 77' 429 motor,,if thios helps
Old Jun 4, 2003 | 08:06 AM
Just Strokin's Avatar
Just Strokin
Normally on a Ford, #1 plug on the cap for a 429/460 is close to the water outlet on the intake manifold. Most distributor caps have a numeral '1' molded into them. Then the plug wires are put going counter-clockwise. That is the next wire will go to the left of number one and so forth till you have all the wires on the cap.
Number one plug (as looking from the front of the engine over the radiator) will be on your left (passenger) side of the engine in front. The cylinders are number 1-2-3-4 on passenger side and 5-6-7-8 on the driver's side.
The thing that might be the problem, someone might have removed the distributor years ago and number 1 is not where it should be.
Phillipjohn
13
Feb 21, 2016 02:45 PM
darf5592
Mar 15, 2015 09:10 AM
Go Roush
1983 - 2012 Ranger & B-Series
Dec 16, 2009 06:59 PM
keyzdiver
Nov 27, 2007 10:41 PM
Tarun
Nov 11, 1999 10:24 AM
