Normal oil consumption for 460?
203,000 miles and mine uses about a quart every 3000 miles, not one wrench turned on the motor. 40 psi oil pressure at hot idle, 60 at cruise. 1993 F-250 4X4 ZF 5-speed.
All depends on engine condition and random engine variations. My 94 460 with 70,000+(maybe 20K towing) burns maybe half a quart in 7,500 miles using Valvoline synthetic.
Other engines I have owned usually burned maybe 1 quart between oil changes if they were in decent condition. I have had some engines where I knew I had a oil leak and those might "burn" a quart every thousand or two. Some manufacturers do consider a quart every 1,000 as within norms, but most mechanics would disagree. I think most mechanics would view a quart every 2,000 assuming no leaks as the minimum acceptable.
Just my thoughts, based on probably over a million miles, hundreds of oil changes and maybe a dozen personal vehicles.
Jim Henderson
Jim Henderson
460, 94, big, blocknormal, comsumption, consume, consumption, engines, ford, leak, oil, towing, troubleshooting, usage
