Axle clunking
Old Mar 31, 2013 | 10:12 PM
HumminFummins's Avatar
HumminFummins
Axle clunking
When I am driving I hear and feel a clunking in the floor boards. Sounds like the left front. I just did the ball joints, but I noticed I could move the axle up and down about 3/4 of an inch or so. Could it be bad locking hubs? Everything else is tight.
Old Mar 31, 2013 | 10:33 PM
farmert's Avatar
farmert
Sounds more like a worn out spindle bearing, if you are getting that movement at the steering nuckle u-joint.
Old Mar 31, 2013 | 11:03 PM
tshrager's Avatar
tshrager
I'm getting the exact same thing and for the life of me, I can't find it. Everything is tight up front, but there is a definite noise when I hit bumps at low speed.
Old Mar 31, 2013 | 11:06 PM
FI460's Avatar
FI460
My experience is with the Super Duty but usually a clunking going over bumps/pot holes is either ball joints or sway bar bushings/end links.
Old Mar 31, 2013 | 11:09 PM
tshrager's Avatar
tshrager
That's been my experience as well Rick, but I've generally found that there's a good amount of slop in them when they go bad. Everything is tight and the OP had recently done ball joints.
Old Apr 1, 2013 | 06:44 AM
Hussler's Avatar
Hussler
Tighten up the fender bolts as they can cause a loud clunking noise, usually left front area, when going over uneven surfaces at low speeds.
Old Apr 1, 2013 | 11:14 AM
tshrager's Avatar
tshrager
Thanks Jim, this took care of my noise! Reps tried, but no go...
Old Apr 1, 2013 | 11:31 AM
BuckHammer's Avatar
BuckHammer
Are you sure it's not the engine that's causing the problem?
I'm just kidding, man.
Old Apr 1, 2013 | 01:08 PM
tshrager's Avatar
tshrager
Old Apr 3, 2013 | 05:22 PM
Usaman's Avatar
Usaman
Caught them bolts last summer from someones write up...unbelieveble fix!!!! Thought it was more cash flying out the window but that fix nailed it!!!! Now to do my hinges when it gets hot out....
bubba.whit6.4
6.4L Power Stroke Diesel
Jun 28, 2016 09:42 PM
xsportplyer
Sep 20, 2012 11:55 PM
Mike Allen
Oct 29, 2009 05:20 PM
tloo13
Oct 21, 2008 05:00 PM
foxracer800
May 30, 2006 04:25 PM
