Key switch
Old Mar 31, 2013 | 09:08 PM
oliver28472's Avatar
oliver28472
Key switch
My brother has a 1987 F-250 diesel with no key. Is there a way to change out the switch with no key?
Old Mar 31, 2013 | 09:16 PM
DBGrif91's Avatar
DBGrif91
Yes.
There's a small hole under the ignition tumbler (switch). This is where the retainer pin is- you'll need to drill it out w/ an 1/8" bit. Then you can remove the tumbler.
Old Apr 24, 2013 | 09:33 AM
oliver28472
This did not work. The tumbler needs to be able to be turned to a position before it can be removed. Caused a lot of extra work. Can't turn it without the key.
Old Apr 24, 2013 | 05:18 PM
tjc transport's Avatar
tjc transport
i ain't rite
this should get you going
Ford Truck Enthusiasts Forums - View Single Post - Ignition Cylinder Replacement (Without the Key)(With Pics)
romoshka
23
Apr 14, 2022 04:07 AM
7.3 Rocket
Oct 25, 2010 08:23 PM
63beater
Apr 18, 2009 08:19 AM
66F100Again
Dec 9, 2006 05:41 PM
dupontj
Jun 20, 2004 07:35 AM
