460 header
Old Mar 31, 2013 | 10:59 AM
brian_06328's Avatar
brian_06328
460 header
I have a '96 F350 4x4 with the 460, the passenger side exhaust manifold is cracked which I hear is pretty normal for these when they are used for towing. I want a header that will bolt in to the stock Y-pipe (so I don't have to have a new Y-pipe welded in like with the Thorley) but would like some opinions on who makes a good quality header that will fit on this engine. I'd like a 3/8 flange and heavy tube material, I really would like it to bolt in without modification since I don't have the free time I used to.
It already has 3" pipe, a high flow cat and a 70 series Flowmaster. Might as well complete the exhuast.
Thanks in advance
Brian
Old Apr 1, 2013 | 08:46 AM
KhanTyranitar's Avatar
KhanTyranitar
JBA hands down.
Old Apr 1, 2013 | 06:09 PM
V10man's Avatar
V10man
JBA doesnt make a set. Only "shorties" I found were Hedman's. The rest seem to come with a new Y pipe. My guess it is a matched system, the Y helps with performance. Should be a stock bolt in however. It does sound like you did change some things so it may require some work.
f100beatertruck
Jun 25, 2013 06:11 PM
copracer288
24
Jun 11, 2009 10:19 AM
Ken Blythen
Exhaust Systems
Oct 20, 2007 07:47 PM
John with beastly 302
Exhaust Systems
Nov 7, 2005 08:24 PM
Zinfinity
Exhaust Systems
Feb 29, 2004 01:13 PM
