Need Muffler
Old Apr 3, 2013 | 09:38 PM
GordonL's Avatar
GordonL
Need Muffler
I have a 97 F250, 351, auto, that needs a new exhaust system. I'm going to gut the catalytic converter, replace the pipes and muffler. The mufflers that the local shops have been putting on are crap, they sound like crap and they don't last long. I would like to find a better muffler. I want it to be quiet without hurting performance, 3" inlet and 3" outlet, and fits in original stock position under the bed. What would you recommend and where can I get it? Thanks!
Old Apr 3, 2013 | 11:58 PM
KhanTyranitar's Avatar
KhanTyranitar
WickedFlow Max series. Excellent quality, great price. I've been using them on my own for years, quieter and cleaner sounding than a Magnaflow, better flowing too.
Old Apr 4, 2013 | 09:50 PM
V10man's Avatar
V10man
My son and I did this to his 96 F250. At the flange where both head pipes come together, we welded a Flomaster Y pipe to the flange to get a single 3" pipe(also makes it removable by unbolting the flange) He then bought a Magnaflow 3" in/out round muffler, not very long, then turned the exhaust out infront of the rear tire. I like it but it may be a tad loud. Longer muffler would change that. I wouldn't gut the cat because it becomes a huge chamber and can hurt flow. If you need it for a visual then re pipe it with 3".
Old Apr 9, 2013 | 08:10 PM
Beechkid's Avatar
Beechkid
Here's the DB levels for most of the more popular mufflers- factory is typically less than 70 dB's:
MUFFLER Idle dB WOT dB
DynoMax Super Turbo 89 123
DynoMax Race Magnum 94 133
Flowtech Afterburner 92 124
Hooker Competion 92 122
Hooker Super Competion 90 125
Summit Turbo 89 124
Summit Fully Welded 92 125
Thrush Boss Turbo 90 123
Thrush Magnum Glasspack 92 128
DYNO TEST
All mufflers were dyno-tested on a 355-cube SBC with 10.0:1 compression, Air Flow Research 190 aluminum heads, a CompCams 292 hyd. a Victor Jr. intake, a Holley 750-cfm double-pumper, and 1 5/8 Headman headers.
Allied resonators (that sell for about $40 each and available at any muffler shop nationwide) are excellent and come in just about any diameter and length (10" to 38" IIRR). Another excellent factory OEM replacement unit is Walker.
Michael Manglos
Oct 16, 2012 02:32 PM
rvx290
Exhaust Systems
Dec 17, 2009 10:03 AM
paintslinga2010
Exhaust Systems
Oct 22, 2007 11:29 PM
jgoshow
18
Jun 22, 2005 06:57 PM
54 Oldsman
Jan 2, 2003 04:52 PM
