Sponsored by: Real Truck
Problem with 2WD leveling kit
Old Mar 31, 2013 | 12:16 AM
99F250SDfromCA's Avatar
99F250SDfromCA
Hey guys, Im new to FTE and need a little help. I have a 99 F250 SD 2WD that I recently installed a 2" leveling kit on. The install went fine but now my camber is way off. Firestone said I'm 3 degrees positive. During the install I didnt have spring clamps, so to get the springs in I unbolted the sway bar links to drop the wheel. I then had to jack up the wheel to bolt the sway bar links back up, which had to compress the springs quite a bit. Now to my question... Would it be a good idea to just get longer sway bar links to relieve the springs a bit or should I just get the centric dual axis bushings to adjust the 3 degrees? Please help!!!!!! Thank you, Elijah
Boilermaker1994
Jun 29, 2016 02:33 PM
adam10
Aug 17, 2014 11:33 AM
snorindad
May 8, 2013 08:51 PM
415boy
Sep 26, 2007 11:46 AM
riley42204
Nov 9, 2005 06:16 AM
