New guy need help- 3spd shifter woes
Old Mar 30, 2013 | 07:26 PM
stp1971's Avatar
stp1971
Great forum and awesome info!! I have a little problem. I have pulled the steering wheel, turn signal collar, and the shift collar off the column. I am replacing the thrust washers and the spacer at the bottom of the shifter sleeve. Well I am attempting to do so. I have pulled the shifter sleeve/tube out but I don't know what I need to do in order to get the steering shaft out so I can slide the thrust washers and the spacer out.
I ordered some bushing kits from LMC Truck that I "think" are to go on the two shifter pieces on the column. They don't look anything like what is on there.
Any help would be greatly appreciated. The truck is a 1978 F100 3spd on the column with a 300ci.
skotyg
Sep 12, 2013 06:08 PM
Brother F
Jul 23, 2012 07:59 PM
rob8210
May 14, 2008 06:51 AM
smihans
20
Dec 23, 2006 12:40 AM
MSC
May 10, 2004 09:28 PM
