Ranger Transmissions
Old Mar 30, 2013 | 03:21 PM
grilldemon's Avatar
grilldemon
My father has trashed his 5 speed in his 95 4.0L 2wd. He has found one in a 2000 B4000. I'm thinking it should fit. CAn anyone confirm?????
Old Mar 30, 2013 | 11:42 PM
19704X4F250's Avatar
19704X4F250
Depends. What is the engine in the 2000 and what is the transmission in the '95?
Old Mar 31, 2013 | 03:06 AM
Pablo-UA's Avatar
Pablo-UA
2.8/2.9 and 4.0 share bellhousing pattern
3.0 differs
Old Mar 31, 2013 | 04:06 PM
grilldemon's Avatar
grilldemon
They are both 4.0. Don't know what trans is in the 95
Old Apr 1, 2013 | 08:18 AM
19704X4F250
I will go out on a limb and say it "should" fit. Pay close attention to total transmission length and any sensors that may have been added/deleted since 1995. The Mazda transmission is stronger than a Mitsu, which what probably was in the '95.
Old Apr 1, 2013 | 08:32 AM
KhanTyranitar's Avatar
KhanTyranitar
Both the '95 and the '00 use the M50D which is total junk. That said, why not fix the one he has rather than swapping in someone elses mystery box?
Old Apr 1, 2013 | 08:51 AM
Pablo-UA's Avatar
Pablo-UA
Yep, but to use other tanny is not so easy.
ok, you can use ZF T5 ore Mercedes 6 st tranny with adapter plate and custom DS
Old Apr 3, 2013 | 11:24 AM
19704X4F250
You may have to argue that point with those at the rangerstation....."Rather than rebuilding it or replacing with another FM146, I installed a M5OD transmission because it is a stronger transmission and should last longer."
Transmission Swap (FM146 to M5OD) and Complete Clutch Upgrade
Old Apr 3, 2013 | 12:08 PM
Josh S's Avatar
Josh S
I would tend to agree with that. Based solely on my own experience I've been very happy with my M5OD that is still working well with 208,000 miles on it. Definately an improvement over my FM146 IMHO.
jimmy dale
Jan 28, 2018 10:19 AM
Taumac
Dec 30, 2009 05:19 PM
scrapyardking
Oct 27, 2008 11:04 PM
volcom fsmx
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 18, 2004 03:52 AM
