Sponsored by: Real Truck
Sloppy Front End
Old Mar 30, 2013 | 02:58 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Sloppy Front End
Ever since I was drug up onto a flat bed by a tow truck operator my front end has been very sloppy. So much so that I was pulled over for suspicion of DUI. TWO people called and reported me. The officer followed me and didn't witness anything but just stopped me to make sure I wasn't drowsy. I explained it to him and he said no problem.
What happens is I have to maintain a slight right hand pull to go straight and sometimes it will start to wander left. Also the steering is loose feeling.
I went in for an alignment and they said they couldn't do it because the tie rod end had too much play. What is the validity to this? Also, what else should I check for play?
I also have new tires now and this has helped significantly.
Old Mar 30, 2013 | 04:06 PM
Firekite's Avatar
Firekite
Why wouldn't you go ahead and change out your rod ends?
Old Mar 30, 2013 | 05:02 PM
02TB250's Avatar
02TB250
The upper and lower drag links, the tie rods and the steering box can all lead to steering wobble or a "loose" front end. They're all very closely related to how the vehicle rides down the road.
Old Mar 30, 2013 | 09:27 PM
CuNmUdF250's Avatar
CuNmUdF250
the shop that does the alignments on our company vans won`t touch them if they have worn out parts
Old Mar 30, 2013 | 11:02 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I'm gonna replace the tie rod ends, just need to know what all to check
AKHunter93
21
Aug 19, 2016 01:10 AM
bburrito
Jun 23, 2010 11:50 AM
Chad102
May 26, 2010 03:58 AM
dfishrmn88
2004 - 2008 F150
Oct 31, 2009 10:55 AM
bigricker
16
Nov 24, 2001 08:28 PM
