e4od won't engage after install
Old Mar 29, 2013 | 08:18 PM
John Clugston's Avatar
John Clugston
Last transmission overheated. I replaced with a used one, 150k on truck. ford quality renewal sticker not sure on miles after rebuild. From a 92 f-350. Bought a new triple clutch torque converter. All sensors are plugged in, fluid in transfercase, added 13 quartz to transmission. Fluid level won't go down. My reverse lights wont turn on and i can only crank in park. Cannot crank in neutral. First time i started it the overdrive light was flashing. I shut it off and started it back up and it was not flashing. When the last transmission failed the overdrive light was not working
Old Mar 29, 2013 | 10:53 PM
speedwrench72's Avatar
speedwrench72
did u forget the tork converter bolts?,,it holds more than 13 qrts,,recheck the wireing and conectors,, and grounds...
Old Mar 30, 2013 | 05:57 AM
John Clugston
I remembered to install the nuts, even bought new ones from Ford. I know it holds more, 16? I think is what it calls for. I installed all new lines and a aux cooler bypassing the radiator and factory cooler. Aux cooler is rated for 27k gvw, so be no means to small and I have a trans gauge.
Old Mar 30, 2013 | 07:59 PM
John Clugston
After tearing down transmission, turns out trans pump gear was broken.
maherc84
Aug 11, 2018 11:17 AM
mrad
Jul 10, 2012 03:11 PM
96f150
May 25, 2010 10:22 PM
JOHN CHAPPELL
Jan 14, 2008 12:45 PM
zobie18
Aug 27, 2007 12:18 AM
