1997 F350 7.5 DRW Transmission stutters in reverse. No 3rd after warming up. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Reload this Page >
Old 07-22-2018, 09:23 AM
maherc84
maherc84 is offline
maherc84 is starting off with a positive reputation.
New to this so I hope I am posting in the right place. We have two trucks, a 1997 F350 Box truck with a 7.5 and a e4od and a 1999 F350 box truck with a v10 with DRW. Both of these have had the transmissions rebuilt several times, with only a few hundred miles in between each blow out or problem. Both done by the same guy, at the same shop that is no longer to be found. To make a long story short, the 1997 with the e4od shut down and blew fluid out of the front of the case the other day again. No third gear, revving and not going anywhere, OD off light on then came the blast of tranny fluid, a 40 foot trail of tranny fluid and then I was stopped dead in the road. Now the 1999 is starting the same thing. No 3rd gear after it gets hot. Stutters in reverse. Can't get over 30mph and the tranny is screaming. We are about to drop these ourselves and need help. The solenoid harness on the 1997 was replaced because it was melted but this didnt cause the issue. It was doing the same thing before. Hopefully I'm giving enough information to start a decent thread. Any and all questions and help is appreciated. Oh, and the mechanic that subbed out the rebuild wont honor a mileage warranty. It's just "one year from the original rebuild" which has since past because it's been rebuilt so many times. Thanks!
Old 07-22-2018, 09:50 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Shuddering in reverse an no third gear indicates that the direct clutch has failed. I'm sorry, but it needs to come out and be rebuilt again. Hopefully this time by someone that knows what they are doing.
You should also replace the radiator and the aux trans cooler. With all of those failures, the trans coolers are going to be full of debris. There is NO effective way to totally clean these coolers. If you don't replace them sooner or later some piece of debris will work it's way loose, get into the new transmission, and cause yet another failure.
Old 08-11-2018, 11:04 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
F-250 WARHORSE has a good reputation on FTE.F-250 WARHORSE has a good reputation on FTE.
clean lines, clean coolers, inspect and or replace torque converter, it is full of junk, sounds like a real winner, "I can take care of that, bring it down..... ordinarily this would be a big job.... um ..... about $1600 but yours is a unit we have a kit for from the space time continuum transition and we can get that knocked out for ya, take about $299 with a 24 month warranty, but if fails while the moon is in the wrong phase, it becomes customer pay......" Good luck finding a good tranny guy, but ordinarily most of the local garages that are reputable charge more than the truck is worth, on a 20+ year old build, but they will still be in business in 5 years and you get what you pay for.
It is not uncommon for a 1990s vehicle to go into a garage and have the repair ticket exceed the value of the vehicle. Some customers pay it and some don't, but that is not uncommon for a proprietor write an estimate that comes to 3000 - 4000 dollars for a vehicle service that includes a transmission reman, install, cooler and lines, u joint(s) wiring harness repair/replace (e4od has a issue here) and the thing comes back tight and right, and the truck is worth about $3000 dollars!
Old 08-11-2018, 12:17 PM
maherc84
maherc84 is offline
It already blew out. No 3rd gear, OD light flashed, then boom. Fluid everywhere. We are going to pull it ourselves and just see if it's the front seal and go from there. The whole front end is coming out and getting a new radiator, thermostat and cooler. Enough is enough.
Jesser02EX
20
09-15-2015 10:02 AM
rowekmr
1999 to 2016 Super Duty
02-10-2015 08:27 PM
xsfg
11-03-2013 10:52 PM
MONAVIERONJON
02-06-2012 10:53 AM
BowDown
04-19-2006 02:14 PM
Quick Reply: 1997 F350 7.5 DRW Transmission stutters in reverse. No 3rd after warming up.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
