Im thinking about the 6637 Air Filter mod. The latest kit has the dust cover. It just seems its being starved for air.
Any comments on this? Go, no go??
My worries are underhood air, sensors, filter minder (saw the mod) and a big unsupported filter bouncing around.
I started by looking at the high dollar filters with the 'box' around it. Not sure I want to spend $300 plus on it though. Was thinking about making my own box from a cheap plastic battery box but the 6637 filter seems so big.
Opinions welcome.
Thanks.
JC
Dont worry it will not bounce around, its too big! i got mine from Riff Raff, you can do it cheaper your self, but if you want the cover just get the kit. It will be quite a bit louder than a stock box.
Ok, so this morning I had the muffler replaced with a pipe. It sounds great and sends more of the noise out the back instead of into the cab. Its still fairly quiet too and only cost me $40!
I ordered the 6637 from RiffRaff so that will go on next week.
I figured out my keyless code, took 3 minutes, it was in the 5th line of codes.
On my way to the dealer for the headlamp switch ****, a running board lamp socket and a CPS.
On the way home I'll pick up a new belt and the upper hose that goes around it instead of through it. <-- Why we did that I'll never know. The service engineer should have killed it....must have missed that meeting.
I love this site and thank you guys for all the help. Reps coming!!!
Before you go, check to see if you still have the original black CPS, or if it's already been replaced with a grey one.
If you have the black CPS, and their computer shows the CPS recall is still outstanding, they'll take your black one and replace it with a grey one. Don't let them do that because they won't let you keep the black one, and that's the one you want.
Stewart
Just went to get a spare. Havent looked at whats on there yet. Runs good, no trouble.
What application is the upper rad hose that goes around the belt instead of through it?
I took apart the rear hatch to fix the ajar issue. Very easy. Wow were they dirty. This will be a yearly thing for me.
Also did the fog lamp mod.
And, last but not least for the day, my wife drove it and likes it. Now Im in trouble. hahaha
Stopping on the way home today for the belt and hose.
Noticed something this morning. Fired it up and got blasted in the face, so to speak, with exhaust fumes. Thinking it could be a couple of different things: I park with the exhaust side aiming toward a fence, could be blowing back in a bad rear window seal....or.....the downpipe is not tight on the turbo and its coming in through the firewall or vents. Im thinking the latter as it was almost instant. Going to do some close inspection when I get home, cant have this continue. Any experience or tips appreciated.
I've also been seeing mods regarding the fuel bypass/return. I was looking at the RiffRaff kit. Do this now or it can wait?? Seems like an affordable upgrade.
This evening I will be pulling the cluster to deal with the lighting. Will also look at the shifter stalk wiring and adding protection as suggested.
I had the door ajar problem when I bought our 2003 6l diesel a few months ago. Pretty sure the rear hatch was the culprit.
Two things:
1. if the hatch slams hard, the lifts need to be replaced. That will help with the door ajar issue.
2. I sprayed a lot of WD40 (it will make a mess so have paper towel handy to catch all the liquid) in both sides of the hatch where the latches are. The sensors for the door ajar are in the latches. Same with all four doors.
I sprayed the latches for all four doors and both the left and right hatch latches, replaced the lifts and the problem went away.
Two things:
Yeah, I pretty much took my hatch apart and cleaned everything, latches and switches included. My release handle was sticking so I took care of that too. I read somewhere on here about a slightly longer shock that will lift it up a bit more without hitting the roof. Need to find that post again. I'll replace with those so I dont knock the bean on the hatch.
On another note, I found a pair of new SD front springs for $100!! Im going to double check the part number but the application is spot on for what they were originally purchased for. Major score!
