f450 brakes & rotors
Old 03-27-2013, 09:26 AM
jimcb1's Avatar
jimcb1
jimcb1 is offline
how many miles is everyone getting with 2011 F450 on there brakes and rotors i have 37,500 miles and dealer said need new ones at a price of $ 1,350.00 does that sound right seems high to me
Old 03-27-2013, 09:37 AM
gwcon's Avatar
gwcon
gwcon is offline
Have you been hauling very heavy for all of those miles? I have had F350's with almost twice your mileage towing 85% of the time and the brakes have been fine. I wonder if you need to go see another dealer for another opinion. Just my 2 cents.
Old 03-27-2013, 09:42 AM
gwcon's Avatar
gwcon
gwcon is offline
Forgot to mention that all my trailers have brakes. Have you checked your trailer brakes lately? That definately could make a difference. Another 2 cents worth.
Old 03-27-2013, 10:03 AM
jimcb1's Avatar
jimcb1
jimcb1 is offline
towing 5,000lb snowmobile trailer
Old 03-27-2013, 10:14 AM
gwcon's Avatar
gwcon
gwcon is offline
Wow! Even if you have no brakes on that trailer and towed it everyday there is no way your brakes should be worn out. Get another opinion.
Old 03-27-2013, 10:40 AM
Sark's Avatar
Sark
Sark is offline
Something is not right.
My 04 F350 CC DRW has 87,000 on it with 60+k towing our 37ft. 1/5whl, gross weight trk & trailer 21+k. I did the fronts @ 57K with 15% left on the pads & I'm still running the org. pads on the rear. I ck them often & the rears still have about 15 to 20% to go.
Get a diff. opinion.
Old 03-27-2013, 10:50 AM
porthole's Avatar
porthole
porthole is offline
Either learn how to check and do yourself or find a dealer you can trust. Doesn't sound right unless you have a mechanical problem.
Why were the brakes checked? Issues or just an inspection?
Old 03-27-2013, 12:34 PM
jimcb1's Avatar
jimcb1
jimcb1 is offline
i was hearing a squeling sound
Old 03-27-2013, 12:38 PM
jimcb1's Avatar
jimcb1
jimcb1 is offline
how do you set the right amount of gain on the brake controller
Old 03-27-2013, 12:47 PM
gwcon's Avatar
gwcon
gwcon is offline
Set the brake controller so that your trailer wheels don't lock up while you are still slowing down. The trailer should slow smoothly with your truck no bucking. With only 5K you probably don't need but maybe 5.5 or 6 I would guess however, I'm sure every trailer is different. With 17K I have mine set on 8.5.
Old 03-27-2013, 12:49 PM
gwcon's Avatar
gwcon
gwcon is offline
A squeeling noise and you need all new brakes all the way around??? I think your dealer is trying to take you for a profitable ride.
Old 03-27-2013, 01:21 PM
porthole's Avatar
porthole
porthole is offline
Valid enough to have an inspection.
But for what it is worth, brakes are one of the most profitable maintenance items on vehicles for the servicing center, dealer or independent.
Old 03-27-2013, 08:05 PM
marchare011's Avatar
marchare011
marchare011 is offline
There have also been some models of 2011-2012 with caliper sticking issues. Make sure you're not paying for warranty work. Most decent tire stores will do a brake inspection for free. I would look around.
diego-ted
12-18-2014 01:18 PM
Robert6401
10-24-2011 08:29 AM
Skattracker3
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
02-24-2010 06:33 PM
Capt Dan
03-04-2007 04:01 PM
rivershark33
1999 to 2016 Super Duty
10-17-2006 10:19 PM
Quick Reply: f450 brakes & rotors
